April 24, 2014, 01:38:50 PM *
Pages: 1 [2] 3 4 5
Author Topic: Amplification: what are you using?  (Read 25038 times)
pablo basso
« Reply #15 on: June 01, 2010, 02:30:12 AM »
Ashdown 550 Spyder with ABM 210 and ABM 115...The sound of Thunder
BASS COLLECTOR
« Reply #16 on: June 01, 2010, 07:04:52 AM »
I use Aguilar    Wink
« Reply #17 on: June 01, 2010, 11:02:15 AM »
Shuttle 9.0 and Berg AE410...but lately I've been feeling like it lacks low end booty.  Nothing adding a 115 to the mix wouldn't, but the Berg AE410 is a 4 Ohm cab so I'm think about rearranging my whole rig.
« Reply #18 on: June 03, 2010, 12:28:15 PM »
The AG500 has since been sold.
« Reply #19 on: June 03, 2010, 11:19:33 PM »
Favorite of all-time:  Aguilar DB750 thru Accugroove Whappo Jr
2nd:  DB750 thru Accugroove Tri 115L
3rd: Markbass LMII thru Accugroove Tri112L
Dying to get as a backup:  AG500SC.
Obscenely loud gig:  DB750 thru Whappo Jr/Tri115L/Tri112L
« Reply #20 on: June 04, 2010, 02:10:11 AM »
I use Aguilar    Wink
Is that a dbx graphic eq I see? If so, please tell me about how it's working for you. I use a dbx 160a comp. & have debated getting a dbx eq. to pair w/ it but I'm not convinced.
Thanks bro.
lowb_2277
« Reply #21 on: June 04, 2010, 11:31:08 AM »
I use Aguilar    Wink
Geez Andrew, I believe that would be called the "ability to move some air"
Vintage 5 string, 24 fret 5 string, P/J 5
toby
« Reply #22 on: June 04, 2010, 12:23:03 PM »
For most Rock gigs I use either a Thunderfunk 750 or Orange Terror Bass into 1 - 4 Aggie GS112's, Worship same head choices into an Acme Low B2, rehearsal TFunk 550 through a DR Bass 2460 and I use a Mesa Walkabout Scout when a combo is the proper choice.
My R5/24 into a TFunk 750 with 3 GS112's has got to be my fav "rock" rig, the tone is fat, rich and quick with enough volume for almost any gig
BASS COLLECTOR
« Reply #23 on: June 04, 2010, 08:05:50 PM »
Hey guys!
P.Bass, that is just a Korg DTR2000 tuner in that rack
lowb, yeah mate, move major air they do!!!!   Cool   "nice sounding" air also    Grin
Burk
« Reply #24 on: June 08, 2010, 09:47:47 AM »
I'm running a T-Funk 550 thru a Low Down Sound 210 UL.
« Reply #25 on: June 08, 2010, 07:44:11 PM »
Aguilar DB 750
Aguilar GS 410
Darn guys my 410 cab has blown speaker or speakers. What do I do? Any sugestions.
Lui
« Reply #26 on: June 08, 2010, 09:26:13 PM »
Greetings,
Pure and simple.
Ampeg SVT-CL Bass Head
Trace Elliot Quatra Valve (Purchased 1990 via Chris Maury at "The Bass Centre"/Hollywood)
Ampeg SVT 810 E
Lui
« Reply #27 on: June 08, 2010, 09:28:53 PM »
Oops, btw... The SVT-CL - Hot rodded and NASTY!
« Reply #28 on: June 09, 2010, 12:41:42 PM »
TC 450 plus a Berg NV215.
« Reply #29 on: June 13, 2010, 09:57:49 AM »
Current setup:
Pre-amp: Vanderkley VA615 www.vanderkleyamp.nl/va615.html
The Vanderkley VA615 is a fully hand-wired all tube (2x ECC 83/12AX7) bass pre-amplifier.
This preamp is designed to maintain a brilliant, natural, open and deep bass sound under all circumstances.
The unit has very large headroom and extremely low noise and hum making it one of the most silent preamps on the market. High input impedances, low output impedances make it possible to drive difficult loads and/or use long cables.
With the Eq-section switched off the preamp gives natural open sound, when the Eq is switched on this natural character is maintained. The 5-band passive tone controls with first order (6dB/octave) shelving or band-pass filters are used to tune the sound to your personal requirements. This type of tone control guarantees an open and musical character at each setting.
The VA615 has a built in parallel effect-loop with phase correction for true deep bass reproduction. The level of effect can be added to your original signal via a potentiometer on the front panel.
A floating transformer prevents any ground-loop hum when the balanced D.I. output is used. This makes the D.I. extremely silent and therefore suitable for advanced studio applications. In a worst-case live situation, there is also a ground-lift switch on the back- panel.
The preamp is not sensitive to mains clicks and distortions on mains voltage variations and features a soft switch on/off.
Poweramp: Lab-Gruppen fp3400 2 x 1500 Watt/4 Ohm  www.labgruppen.com/products/fp_series/c/fp_3400/
Cabs: Vanderkley 212 NeoLite    Vanderkley 212 Neolite (2x) (1000 Watt/4 Ohm) http://vanderkley.blogspot.com/2009_10_01_archive.html#8871673319920689379
Previus owned:
SWR Goliath
EDEN XLT
Glockenklang Take V
Epifani 212UL and 210UL
Alembic F1-x + SF-2
Epifani Quest II
Crown K1
Powersoft D Digam 4002
« Last Edit: June 21, 2010, 02:19:12 PM by Funnybass » Logged
Pages: 1 [2] 3 4 5
