October 24, 2014, 04:30:45 PM *
Author Topic: Help with buzzing  (Read 2370 times)
the swank one
« on: November 21, 2010, 02:02:26 AM »
on my metro will lee i seem to have buzzing on the E & A strings only. it seems to be mostly when they're played open. is it something i'm doing or is it the bass? i've only had it for a few months so the strings and setup is the way it shipped from sadowsky nyc Huh
« Reply #1 on: November 21, 2010, 02:39:28 AM »
Perhaps your neck is adjusting to the weather changes with Winter coming.
If you're inexperienced with adjusting things, I'd contact Sadowsky guitars or find a reputable local professional to do a setup for you.
I do all my own.
I'm also venturing to guess you're just needing a slight truss rod tweak.
« Reply #2 on: December 01, 2010, 10:06:14 AM »
If you get buzz on open strings and on the first few frets you should probably loosen the truss rod a bit to make the neck straight.
If it is straight and you only get buzz on open strings but NOT on the first & second frets the nut might be cut too low, which is highly unlikely.
A phone call to the shop is the best thing you can do, IMO.
« Last Edit: December 01, 2010, 10:10:31 AM by RonenTat » Logged
